IO modules
Multi-functional design of slots
Murrelektronik‘s Solid67 IO modules simplify field installations and are particularly suitable for applications with IO-Link sensors and actuators.
© Murrelektronik
They provide eight IO-Link slots in close proximity to the process, but also integrate classic IOs into the system. A fully encapsulated metal housing, vibration-shock values of 15 G and 5 G as well as working in the temperature range between -20 and +70°C provide application possibilities in harsh industrial environments. Diagnostics and troubleshooting can be performed directly on the module as well as via the controller and an integrated web server. The fieldbus modules are multi-protocol capable and support Profinet and EtherNet/IP in a single module. To switch from one protocol to the other, only a rotary switch on the device has to be turned. The M12 power cables (L-coded) are particularly current-carrying and can transmit up to 16 A. The power supply can be looped over several modules. The width is 30 mm.
IIoT gateways
Based on Raspberry Pi
With the RevPi-Connect, Kunbus introduces the newest member of its Revolution Pi product family to the market. The device, designed as an IIoT gateway for machine and plant construction, is housed in a DIN rail housing.
drive controller
Modular interface concept
The flexible SD6 belongs to Stöber‘s family of stand-alone and bayed drive controllers for multi-axis applications. The single-axis controller with a rated output current of up to 85 A controls linear and rotary synchronous servomotors as well as...
