Phoenix Contact
M12 with push-pull locking
Phoenix Contact is expanding its portfolio of M12 connectors with push-pull quick locking and is making the A-, D- and L-coded device connectors with pin contacts available with the matching push-pull housing screw connections for SMD and THR processes.
© Phoenix Contact
Alternatively, there are variants for wave soldering. The push-pull device connectors with pre-assembled strands are suitable for longer distances inside the device. The matching field cable connectors for signal transmission (A-coded) and data transmission in accordance with CAT5 (D-coded) have crimp connections for conductor cross-sections of up to 0.34 mm² or 1 mm².
Quick locking is achieved without tools by simply plugging them in. The user receives clear feedback on the secure connection: if the connectors are not correctly locked, the mechanism springs back into place.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our weekly newsletter and keep your finger on the pulse of automation time. Once a week, on Tuesdays, we provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products. Stay up to date with us.
Our newsletters are of course free of charge and can be canceled at any time!
Click here to register.
Harting
RJ45 replaced
With the 'XTS' transport system, Beckhoff enables flexible machine concepts with highly individualized product transport. In the current generation, an Ethernet interface from Harting replaces the RJ45 interfaces of the computer cards. What are the...
Phoenix Contact
System availability ensured
Even if only one component fails, the entire machine or system can - in the worst case - come to a standstill, as their functions are usually closely interlinked. To prevent this worst-case scenario, every fault must be safely shut down.
