Single-tube linear axles
In stainless steel design
RK Rose+Krieger is launching the E-II stainless steel single-tube linear axis in sizes 30 and 40, to complement the 'E-II' single-tube linear unit for format adjustment.
The stainless steel version is 100% corrosion-resistant and has an extended temperature range of -30 to +80 °C compared to the standard units - a further increase is possible on request. As the stainless steel axes work with FDA-compliant lubricants and can be washed down, they are suitable for width, height and length adjustment in packaging machines in the food industry, for example.
