Single-tube linear axles
Quelle: RK Rose+Krieger | Inka Krischke,
In stainless steel design
RK Rose+Krieger is launching the E-II stainless steel single-tube linear axis in sizes 30 and 40, to complement the 'E-II' single-tube linear unit for format adjustment.
© RK Rose+Warrior
The stainless steel version is 100% corrosion-resistant and has an extended temperature range of -30 to +80 °C compared to the standard units - a further increase is possible on request. As the stainless steel axes work with FDA-compliant lubricants and can be washed down, they are suitable for width, height and length adjustment in packaging machines in the food industry, for example.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
