OKW Enclosure systems
For miniaturized electronic components
Small, robust enclosures are required for the integration of miniaturized electronic components, sensors and wireless technologies. The plastic enclosures in the 'Mini-Data-Box' series from OKW Gehäusesysteme meet these requirements.
According to OKW, the enclosures are suitable for modern indoor and outdoor communication units, for example - they comply with protection class IP40 as standard and up to IP65 with a seal. The enclosures can be used as wall-mounted or desktop devices and as portable applications. They are available from stock in a flame-retardant, UV-resistant ASA+PC-FR (UL 94 V-0) in traffic white (RAL 9016) or anthracite gray (RAL 7016). The basic shape S (Square) is available with 40 mm x 40 mm and 50 mm x 50 mm (LxW) and the basic shape E (Edge) with 40 mm x 60 mm and 50 mm x 70 mm, in 15 and 20 mm heights. The lower parts are also available with a flange, which enables quick wall mounting using screws accessible from the outside.
