Products of the year 2023
Andrea Gillhuber,
Electromechanics - The winners
You can't see them, but they are necessary for the operation of every application: electromechanical components. We present the winners in the electromechanics category.
© WFM
3rd place: Hummel - One Cable for M16, M23 and M40
© Bumblebee
3rd place - Hummel
Hummel presents hybrid connectors in the M16, M23 and M40 series, including the M23 Hybrid Type 2 (4+4+4+PE) with four power contacts. The M23 Hybrid connector is DC-capable, meaning it can also be used in DC networks. The four Ethernet contacts transmit data up to 500 Mbit/s with power processing of up to 28 A/630 V. They are designed for data transmission via Single Pair Ethernet or DSL. More...
The transmission of power, signal and Ethernet in one connector is what makes Hummel's solution so unique, says Markus Henninger, Vice President Product Line Circular Connectors at Hummel. Flexibility is also essential. Find out what this means in terms of connectors in the interview.
2nd place in the electromechanics category
2nd place: Murrelektronik - uKonn-X digital solution
© Murrelektronik
2nd place - Murrelektronik
There is great potential for increasing efficiency in the planning and installation of electrical automation technology. Murrelektronik is therefore presenting a digitally and visually supported system that simplifies the planning and implementation of the electrical installation of machines. The uKonn-X digital solution works as follows: The installer of a machine uses a mobile scanner to read a machine-readable code printed on Murrelektronik's connectors. More...
Murrelektronik's digital solution aims to ensure that you never have to rewire incorrectly again. Sebastian Pfestorf, Team Leader Digital Business, explains exactly how this works.
1st place in the electromechanics category
1st place: Igus - Energy chain made from completely recycled material
© Igus
1st place - Igus
Igus launched the first energy chain product made from 100% recycled materials on the market in 2022: the cradle-chain E2.1.CG is a complete energy chain range made from the new material igumid CG. Numerous tests in our own test laboratory show that the new energy chain has almost the same technical properties and load limits as the energy chain made from the standard material igumid G. It is also available at the same price as the energy chains made from the standard material. More...
One example of sustainability as a competitive factor is the recycled energy chains from Igus. Lena Naumann, head of the chainge division at Igus, knows the challenges that come with a conscious decision for sustainability. She is delighted that the company's commitment has been recognized and already has the next projects in mind.
Plug housing
Storage minimized
Thanks to its modular design, every connector housing from Hummel can be combined with numerous contact inserts so that users can realize almost any number of poles imaginable on the basis of one housing design.
Bumblebee
Michael Nörr joins the Management Board
The connector specialist Hummel from Denzlingen, Baden-Württemberg, has appointed a new Management Board member as of August 1, 2017: As Chief Operation Officer (COO), Michael Nörr is responsible for the areas of production, development and, in...
