Plug connector
Quelle: TE Connectivity | Inka Krischke,
Defy strong vibrations
TE Connectivity is launching a new family of 'industrial mini' I/O cable assemblies with reduced dimensions and a special method for connecting the cables.
© TE Connectivity
According to the manufacturer, the connectors are only a quarter of the size of conventional RJ45 connectors and therefore make optimum use of the limited space on PCBs. Two contact points ensure a reliable connection, allowing the connectors to withstand even strong vibrations. The coded interface prevents faulty connections. The assemblies are available in different cable versions, for example with a 'mini I/O' to an industrial RJ45. They enable a variety of designs for different application requirements, from protection for use in harsh environments to flexible cabling in the control cabinet.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
