Analog modules
Channels individually parameterizable
Wago is expanding the I/O system 750 by adding the module 750-471 with four electrically isolated analog inputs.
© Wago Kontakttechnik
The galvanic isolation of signal inputs is particularly important in areas where interference can occur, for example due to potential differences - for example in marine and offshore applications. The resolution of the inputs of the analog module is 16 bits. The channels can be parameterized individually, either as current inputs of 0 to 20 mA, 4 to 20 mA, 3.6 to 21 mA (NE43) or ±20 mA, or as voltage inputs with the ranges 0 to 10 V, ±10 V and up to the mV range of ±200 mV. The user can individually parameterize the modules according to requirements and only needs one module to be able to record almost all analog encoders.
IIoT gateways
Based on Raspberry Pi
With the RevPi-Connect, Kunbus introduces the newest member of its Revolution Pi product family to the market. The device, designed as an IIoT gateway for machine and plant construction, is housed in a DIN rail housing.
drive controller
Modular interface concept
The flexible SD6 belongs to Stöber‘s family of stand-alone and bayed drive controllers for multi-axis applications. The single-axis controller with a rated output current of up to 85 A controls linear and rotary synchronous servomotors as well as...
