Energy chains
Quelle: Igus | Inka Krischke,
Can be opened from all sides
With the E4.1L, Igus offers what it claims is the easiest to fill e-chain on the market. A special divider system simplifies the individual internal division of the energy chain for the user.
© Igus
The energy chain is easy to open from all sides and can be filled as required. With the divider system, shelves can be easily inserted across several levels to divide the interior as required. In addition, the hinged mechanism of the opening bars in the outer and inner radius enables quick filling with cables and hoses. The captive bars, which can be opened with a screwdriver, can be swung open by 115° and lock into their end position. If required, they can also be completely removed, reinserted and closed by simply pressing them shut. Rounded edges on the opening and separating bars of the chain also ensure a long service life for the hoses and cables. The grid and positioning scale ensure the best possible distribution of the energy chain.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
