Coaxial modules
Quelle: Stäubli Tec-Systems | Inka Krischke,
Also suitable for rail transport
The CombiTac 6 GHz coaxial module from Stäubli enables the connection of 50 Ω RG coaxial cables via a crimp or SMA connection.
© Stäubli Tec-Systems
Two 2.4 GHz versions with crimp connection are available - one for RG58 cables and one for RG316/U, RG174 and RG188 cables. The SMA version allows connection to any 50 Ω RG cable up to 6 GHz such as RG58, RG316/U, RG174, RG188, RG196, RG213 and RG223. Both the crimp and SMA versions are designed for industrial, broadcast, aerospace and defense applications that require high resistance to shock and vibration. The coaxial modules are also suitable for rail transportation as they comply with current fire and smoke protection requirements. Due to the modular design of the module, each crimp or SMA connector can be easily removed or inserted into the coaxial carrier individually and without tools, without having to disassemble the entire connector.
Lapp
Authorized distributors made visible online
Lapp is expanding its digital service portfolio and is the first B2B industrial company to provide its authorized distributors with a verifiable online seal from authorized.by. The company aims to create more transparency and security for buyers and...
