Emotron / CG Drives & Automation
Variable frequency inverter with Active Front End
The Emotron 'Slim-LC' AFE frequency converter uses liquid cooling technology and PEBB (Power Electronic Building Block) modules, enabling higher performance with high reliability and redundancy, according to the manufacturer.
© CG
With an overall efficiency of 97% and a THDi of <5%, the frequency inverter is particularly suitable for applications in the marine, energy and renewable energy sectors where space is limited and harmonics must be kept to a minimum. All Emotron frequency inverters for power ratings from 200 kW consist of one or more PEBB modules. These modules are suitable for 400 V and 365 A, which corresponds to an electrical output of 200 kW. The 690 V modules work with 250 A or 250 kW electrical power. Several of these PEBB modules can be connected together, making outputs of up to 4 MW possible. The PEBBs are intelligent, self-monitoring and interchangeable. The new liquid-cooled PEBB modules have a 100 % higher power density. In addition, PEBBs are mounted directly in the cabinet without a frame, which saves space and material costs. A closed liquid cooling system with a water/water heat exchanger is supplied as standard for cooling the PEBB modules. The frequency inverter is available in two versions: as a frequency inverter with low harmonics (FDUL) and as a regenerative frequency inverter (VFXR).
Drive technology
Triton Partners takes over Flender
Global investment firm Carlyle has signed an agreement to sell Flender, a provider of mechanical drive technology, to Triton Fund 6, advised by Triton. The terms of the transaction were not disclosed and is expected to close in the fourth quarter of...
