Nord Drivesystems
Power range up to 4.0 kW
The IE5+ synchronous motor from Nord Drivesystems is also available in a ventilated or smooth version up to an output of 4.0 kW. On request, the motors are available with a very smooth surface and the 'nsd tupH' surface finish.
© Gear unit construction NORD
According to the manufacturer Nord Drivesystems, the energy-efficient permanent magnet synchronous motors offer high efficiency and a wide torque range. This makes them particularly suitable for economical operation in the partial load range. The motors are just as interesting for intralogistics as they are for hygiene-sensitive areas in the food and pharmaceutical industries.
The motor was presented in size 71 in 2020; size 90 is now available for the power range from 1.1 to 4.0 kW with a continuous torque of 6.8 to 18.2 Nm. Direct motor mounting as well as NEMA and IEC motor mounting are available, encoders and mechanical brakes can be integrated on request. The synchronous motors can be combined with all of the manufacturer's gearboxes and drive electronics in a modular system.
WAY
Geared motors for hazardous areas
WEG is launching ATEX-certified geared motors from the WG20 series, which also enable direct motor mounting. In accordance with 2014/34/EU, the geared motors are suitable for explosion-protected areas of category 2, zone 1/21 and category 3 in zone...
WEG at the SPS 2025
Smart gearbox selection
'Gear ProSelect' from WEG is aimed at all those who are regularly involved in the selection and design of gearboxes and geared motors in mechanical and plant engineering, including design engineers, technical purchasers and OEMs.
