TQ-Group
Housing-less lightweight
The ILM-E from TQ-RoboDrive, a division of TQ, is a variant of its predecessor 'ILM' and represents the next generation of frameless motors.
© TQ-Group
The housingless servo motor weighs just 360 g with a torque of 3 Nm and is therefore half the weight of comparable motors, according to the manufacturer. The areas of application for the ILM-E are wide-ranging: In robotics, for example, the predecessor model has been used successfully for many years. Another target market is medicine, such as operating tables and microscopes, dialysis machines or hospital beds with moving components, for example for the physiotherapeutic mobilization of patients. In mechanical engineering, TQ-Group motors are ideal for operating industrial trucks, measuring machines and industrial systems such as laser welding systems. This is where the high torque comes into its own, allowing even heavy loads to be moved dynamically.
By reducing the reduction ratio, any moments of inertia in the application can be reduced so that the motor achieves high dynamics.
Nord Drivesystems
Power range up to 4.0 kW
The IE5+ synchronous motor from Nord Drivesystems is also available in a ventilated or smooth version up to an output of 4.0 kW. On request, the motors are available with a very smooth surface and the 'nsd tupH' surface finish.
In focus: HMI
The e-paper of issue 06/23
How can digitalization and artificial intelligence help to make production processes sustainable? How can cobots and automated guided vehicles bring variety to everyday working life and how can they support people? Starting points in this issue.
TQ
Four new module series
There are four new module series from TQ: TQMa243xL, TQMa64xxl, TQMa117xl and TQ110EB. TQMa243xL and TQMa64xxL (image) are pin-compatible with each other and are based on the Sitara AM243x and AM64xx series from Texas Instruments.
