Siemens
Portfolio expanded
Siemens is adding new servomotors to its 'Sinamics S210' single-cable servo drive system.
© Siemens
The Simotics S-1FS2, a motor version in a stainless steel housing with protection class IP67/IP69 and high-resolution 22-bit absolute multiturn encoders, is specially designed for the pharmaceutical and food industries. The Simotics S-1FK2 servo planetary geared motors (Fig.) are used when high cycle rates are to be achieved with a lightweight and low-inertia gearbox design or when inertia adjustment is required for the precise movement of heavy loads. The Siemens motors are fully assembled and available as a unit in various gear ratios and sizes. The thermal design is carried out using the digital twin in the TIA Selection Tool.
The Simotics S-1FT2 is a servomotor that offers a variety of different options for the 'Sinamics S210' servo drive system: For example, encoders with a resolution of up to 26 bits improve the system accuracy and the IP67 protection class and various motor paint finishes make the solution suitable for use in harsher environments.
Overview
The top articles in June
New standard, new app store, new security vulnerability - what do these three points have in common? They are among the most-read articles in June! In addition, an unusual human-robot interaction caused quite a stir.
Siemens
AI classification for safety
Artificial intelligence is seen as a solution to current challenges in various areas of life. Politicians are promoting AI, but would like to assess the consequences of the technology and regulate it if necessary. The use of AI for security tasks is...
Industry 4.0
The top dialog
The future-oriented Industry 4.0 project was officially launched at Hannover Messe 2011. The Industry 4.0 platform's research advisory board has now met for a top-level dialog and drafted a twelve-point communiqué on the work still to be done.
Siemens
Edge rack server in robust
The trend towards hyper-convergent infrastructures is not stopping at the manufacturing and automation industry. Siemens has now launched the first edge rack server in robust industrial PC quality. How is the inner workings of the server designed?
