Servotecnica
Performance and dynamics in the smallest of spaces
The SVTN A series micromotors from Servotecnica and the matching 'SVTG A' series micro gearboxes can be used to implement a wide range of drive tasks in a compact installation space and transmit high torques.
© Servotecnica
The brushless micromotors achieve outputs of up to 400 W despite their small diameters of 12 to 40 mm. The lack of cogging torque, low torque ripple, linear correlation between speed and torque, low inertia and low weight increase performance and dynamics.
The brushless micromotors can be fitted with attachable micro planetary gearheads. According to Servotecnica, the lightweight and low-noise drive components are suitable for use in drones, medical technology, robots and active prostheses, exoskeletons or electrical devices.
The micro planetary gearboxes of the 'SVTG A' series with diameters from 3 to 44 mm achieve outputs of up to 300 W. The robustly designed gear stages can be made of steel or plastic.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our weekly newsletter and keep your finger on the pulse of automation. Once a week, we provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
Click here to subscribe.
WAY
Geared motors for hazardous areas
WEG is launching ATEX-certified geared motors from the WG20 series, which also enable direct motor mounting. In accordance with 2014/34/EU, the geared motors are suitable for explosion-protected areas of category 2, zone 1/21 and category 3 in zone...
KEB Automation
Use in disk motors
The Combistop 38 spring-applied brake from KEB Automation is often used as 'Version 38S' in disc motors, for example. Its reduced overall length allows it to be used even in tight installation spaces.
