Lenze at the Logimat 2024
Motorized pulley with 24 V or 48 V
The 'Motorized Roller o450' for direct integration into the conveyor system from Lenze has an output of 115 W and is therefore, according to the manufacturer, more than twice as powerful as comparable systems on the market.
© Lenze
Due to the special design, the motor has significantly lower copper and iron losses overall, which means that less heat is generated in the roller. This in turn has a positive effect on efficiency, as cooler copper windings have a lower resistance (and therefore lower copper losses) and cooler magnets have a higher magnetic flux linkage (and can therefore achieve the same torque with a lower current). Depending on the speed, the motorized roller would therefore meet efficiency classes IE7 to IE9, according to Lenze. The motorized roller can handle up to 30 kg. The motor transfers its rotational energy via its rotor directly to the conveyed goods or the conveyor belt. The destruction motor itself combines a 3-phase AC motor with a loss-free magnetic gearbox. The motorized roller operates at 24 V or 48 V.
Logimat: Hall 5, Stand 5D67
Lenze
Courage to change
In 1998, we were proud of our innovative technology - and we still are - but today we see it as the basis for a cooperative partnership.
WEG at the SPS 2025
Smart gearbox selection
'Gear ProSelect' from WEG is aimed at all those who are regularly involved in the selection and design of gearboxes and geared motors in mechanical and plant engineering, including design engineers, technical purchasers and OEMs.
Lean technology
Easy to implement
Nabtesco
The gearbox makes the robot
How precise, strong and fast a robot is depends on the performance of the gearboxes used. In the white paper, you can find out what is important in the design and how your robot can also benefit from the properties of Nabtesco gearboxes.
