Rollon
Linear axes make lightweight robots mobile
Dahl Automation and Rollon get the lightweight robots from Universal Robots up and running with a simple plug & play solution.
© Rollon
The UR+-certified linear axes of the 'Robot' (closed) and 'R-Smart' (open) series offer high system rigidity, load capacity, torque control, travel speed and positioning accuracy and are precisely matched to the various Universal Robots models in terms of size and performance.
The Rollon axes are part of the 'Dahl Linear Move' all-in-one package, consisting of a configurable linear axis (including motor, gearbox, limit switch and mounting kit), an electronic control cabinet and the 'URCap' software component. The latter guides the user step-by-step through the installation; no special programming knowledge is required. Users can also easily make changes to the production layout themselves at any time.
The plug & play solution is compatible with all UR models of the 'e-Series'
Sigmatek
Intelligent and safe
A new generation of riveting machines relies on servo technology instead of pneumatics and hydraulics. The intelligent drive technology has increased the precision and quality of riveted joints and reduced the number of machine variants.
OnRobot
Grasp like a gecko
With the Single Pad Gecko gripper, OnRobot is launching a compact version of the 'Gecko' gripper, which is particularly space-saving and lightweight. It is designed for three different payloads.
Exner
Robot programs itself
Robot welding processes have been unprofitable in steel construction to date. This has changed with a solution in which the robot programs itself and then welds each component immediately.
Lapp
Fit for direct current
Lapp is launching a robot cable on the market that is explicitly suitable for use with direct current. The Ölflex DC Robot 900 connection cable offers high torsional and bending strength.
Zimmer Group
Robots automate machine tools
In order to increase productivity in production, more and more companies are deciding to interlink and automate their machine tools. The right automation system is crucial. Robots and the right gripping technology play an important role here.
