item
Compact controller for precise linear technology
The integrated 'ST NEMA24-310-48-T1' motor from item Industrietechnik can be connected to the supplier's Linear Units as a plug-and-play component without the need for a separate control unit or complex cabling.
© item
Thanks to the standardized NEMA24 flange and compatible drive sets, integration is quick and easy. The 'Motion Designer' takes care of the technical design: the online software creates a customized combination of drive and linear unit based on individual requirements such as load, stroke and motion profile. The software also offers the option of downloading technical information, analyses and CAD data as project documentation, ideal for further processing in other programs. In addition, the stepper motor from item delivers a torque of 3 Nm at a rated power of 100 W even at low speeds and therefore requires no additional gearbox. This reduces complexity and maintenance costs. The integrated controller also eliminates the need for complex cabling, meaning that even less experienced technicians can commission the motor quickly and safely. The motor can be connected to sensors, limit switches or buttons via digital inputs and outputs. It is particularly suitable for precise tasks with small loads of up to 15 kg, for example in the packaging industry, in mechanical engineering or in high-tech sectors such as semiconductor and medical technology. The 'MotionSoftStepper' software is available for parameterization and commissioning and can be used to program typical motion sequences in just a few minutes. The programs run autonomously on the integrated controller. Predefined operating modes make it easy to get started: the automated application can be implemented quickly by entering just a few parameters.
Drive technology
Triton Partners takes over Flender
Global investment firm Carlyle has signed an agreement to sell Flender, a provider of mechanical drive technology, to Triton Fund 6, advised by Triton. The terms of the transaction were not disclosed and is expected to close in the fourth quarter of...
Humanoids
Schaeffler cooperates with VinDynamics
Schaeffler and VinDynamics, a company of the Vietnamese Vingroup, have agreed on a strategic partnership in the field of humanoid robotics. The collaboration focuses on the development and supply of planetary gearboxes, central components of...
