Ship drives
Quelle: ABB | Inka Krischke,
Increased fuel efficiency
Azipod XL, the latest model of ABB's electric ship propulsion system, increases the fuel efficiency of ships by 20% compared to modern shaft drive systems, according to the supplier.
© ABB
This increase in efficiency is achieved by a nozzle system that accelerates the flow of water into the propeller in order to increase thrust. The thruster has also been redesigned to reduce water resistance. The "Azipod" propulsion system is a gearless, steerable propulsion system in which the electric motor is mounted outside the hull in a submerged nacelle. With the drive rotating through 360°, it is used simultaneously for both steering and propelling a wide variety of ships. The "Azipod XL" concept can be designed in such a way that a high thrust is achieved at a lower speed and good performance characteristics are still achieved at higher speeds. The drive is therefore suitable for tugs and offshore construction vessels as well as ferries and LNG tankers. The drive also allows the system status to be monitored. The concept of the "Internet of Things, Services and People - IoTSP" and ABB's integrated "Marine Operations Center" are used for this purpose.
Logistics systems
New products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of...
Box PCs
IoT device for logistics
The new 'Vehicle Computer Compact M8' embedded box PCs from Syslogic have no moving parts, are shock and vibration resistant and are designed for an operating temperature range of -40 to +85 °C.
Embedded PCs
Suitable for vehicle installation
With the Nuvo-5100VTC, Industrial Computer Source presents an embedded PC that is E-Mark and EN-50155-certified and is therefore suitable for installation in vehicles. The devices are equipped with sixth-generation Intel Core i7, i5 and i3 CPUs.
Tablet PCs
Optional UPS module available
The outdoor tablet PC model 'UPC-F12C-ULT3' from Comp-Mall in an aluminum housing can be used as a mobile or stationary device and is protected against dust and splash water thanks to its all-round IP65/IP66 protection class.
