Advertorial
FAULHABER | Tiffany Dinges,
Drive systems taken further
A FAULHABER drive system is more than the sum of its components. When users combine products with each other, the overall performance of the system increases. Experience the FAULHABER principle of perfectly optimized parameters and interfaces for maximum quality and performance.
© Faulhaber
Taken on its own, each product already meets the highest standards of quality and performance. When application engineers combine our products with each other, the overall performance of the system increases.
This is the FAULHABER principle of perfectly optimized parameters and interfaces for the compact, integrated and powerful drive solutions from FAULHABER, such as the BXT flat motor series with matched gearheads, integrated encoder and speed controller.
All components have been optimized so that they interact perfectly and are as short as possible in the axial direction. With three series (diameter 22/32/42 mm), many high-torque drive tasks (continuous torque of 1, 8 or 18 Nm) can be solved in a very small installation space. Typical applications for the compact drive systems include robotics, prosthetic joints, laboratory automation, pumps, medical technology and aircraft cabin equipment.
Smart logistics: FAULHABER in use
In view of the steady growth in online retail, logistics and material flow are coveted playing fields for technical progress - with the aim of increasing efficiency through automation and digitalization. The young company Magazino from Munich has set out to intelligently combine autonomous driving and robotics. The solution is called TORU and has what it takes to revolutionize logistics. Magazino uses drive solutions from FAULHABER with an integrated motion controller for the handling processes in the self-driving logistics robot.
© Faulhaber
The company's own vision is clearly formulated: Magazino wants to create the world's first self-thinking and self-dealing warehouse. TORU is the name of the new logistics robot, which is currently undergoing practical testing with major shipping service providers. They are using the intelligent, self-propelled system primarily for retrieving shoe boxes as part of order picking. TORU is conceptually a so-called perception-controlled robot that is able to perceive its environment using cameras, image processing, sensors and artificial intelligence, interpret it correctly and make decisions based on this.
The robot's decision
© Faulhaber
Making decisions? When TORU receives an order to pick a specific pair of shoes, it is initially given the warehouse address plus a barcode. The robot knows where the target compartment must be and navigates close to it. The lifting column at the front of the vehicle then turns 90 degrees to the shelf, a gripper moves to the specified compartment and from then on TORU makes its own decisions. The robot first uses three-dimensional camera images to get an idea of the current situation. "Is there even a shoe box on the shelf? Is there the right barcode? Am I even able to grab the shoe box, even though it is a few centimetres out of place and would jam when I pull it out?"
With these questions, Magazino press spokesperson Florin Wahl describes the central tasks of visual analysis. The answers to these questions are what make the system from Munich so unique. If, for example, there is a carton behind a pick order that has been placed slightly askew on the shelf by an employee, the robot adapts its gripping process to the circumstances. If TORU determines that picking will still not be possible, the job is returned to the system - and a warehouse worker would have to do the picking by hand.
© Faulhaber
High overload behavior
Magazino uses FAULHABER type 3268 drives to position the suction pad along a gear rack. With an output of 62 watts, the brushless DC motors deliver rated torques of up to 72 mNm in continuous operation. The peak torques of up to 96 mNm are of interest to Magazino. The overload capacity is crucial in order to safely manage the breakaway torques when handling the shoe boxes. "We need motors with a high power density," explains Raphael Vering from Mechanical Engineering Development at Magazino. As the peak torques are only required in a narrow time window, there are no problems with the motors getting too hot.
The powerful overload behavior of the motors with their diameter of just 32 millimetres brings a number of advantages for the Munich logistics pioneers. The design provides the basis for being able to use smaller motors thanks to the reliable control of the breakaway torques. This means that smaller drives are naturally lighter. "The mass of the gripper must be as low as possible because we have to move it along the vertical axis in the TORU," explains Raphael Vering. The heavier the gripper unit, the greater the required motor power of the vertical axis.
Behind the idea of TORU is a sophisticated system of automation, robotics, vision and autonomous driving. When evaluating the drives, Magazino was therefore looking for solutions with optimum power density. These, in turn, must also be able to be elegantly integrated into the existing automation network. "Support for CANopen communication was crucial for us," recalls Raphael Vering. The fact that the Munich-based company was also able to use a custom-fit motion control solution from FAULHABER gave the development team more freedom to further optimize the new logistics solution.
The FAULHABER company
© Faulhaber
FAULHABER is one of the leading suppliers of high-precision miniature and micro drive systems. The portfolio includes powerful DC motors, brushless DC motors, stepper and linear motors as well as piezo motors. Precision gearboxes, linear components, encoders and drive electronics assemblies for the construction of complete systems are also available. Important applications include production automation and robotics, optical systems, aerospace, medical and laboratory technology. FAULHABER has received numerous awards, for example as TOP100 Innovator or Factory of the Year 2018 in the category "Outstanding Small Series Production". In addition to its headquarters in Schönaich in Baden-Württemberg, FAULHABER has further development and production sites in Switzerland, the USA, Romania and Hungary and is also represented in over 30 countries worldwide. The drive specialist currently employs almost 2,000 people worldwide.
Manner sensor telemetry
Two into one
Manner offers the XtreMA two-in-one dual-range torque transducer for recording multiple rotating torque ranges. This transducer has two torque ranges with two separate and independent signal outputs.
Cellumation
Steer conveyed goods in any direction
The celluveyor conveyor and positioning system from Cellumation consists of small conveyor cells with omnidirectional drive wheels and offers conveyor technology new design and application options for the realization of complex material flows in...
Posital
Two become one
The current situation in robotics: Until now, two single-turn encoders working in parallel - plus gears for synchronization - have been required for speed monitoring and position control per robot arm. A new kit encoder from Posital can now do this...
