Stöber drive technology
Connected at a distance
Stöber Antriebstechnik has further developed the One Cable Solution (OCS) in collaboration with encoder manufacturer Heidenhain and launched the next generation on the market.
One Cable Solution (OCS) from Stöber Antriebstechnik
© Rummager
Using the Heidenhain EnDat 3 protocol, the hybrid cable from Stöber Antriebstechnik can connect motors and drive controllers at a distance of up to 100 m. Users receive a complete system consisting of synchronous servo motor, cable and matching drive controller.
Endat 3 supports the structural design of the 'SC6' and 'SI6' drive controllers. Both drive controllers have the same transceiver chip as the EnDat 3 encoder. The firmware has also been adapted accordingly. The new single-cable solution is designed for the synchronous servomotors of the 'EZ' and 'EZS' series, which can be combined with all Stöber gearboxes in direct mounting. The system consisting of motor, cable and drive controller has an electronic nameplate that enables automatic system installation. During commissioning, each motor automatically sends its own electronically and mechanically relevant data to the associated drive controllers via plug-and-play.
Safety modules
Safe under load
Safeguarding vertical axes is an unpleasant challenge for many plant manufacturers. A safety module for drive-based safety technology provides a remedy. The requirements of the DGUV are also met by means of integrated brake management.
Drive controller
Modular interface concept
The flexible SD6 is part of Stöber's family of stand-alone and modular drive controllers for multi-axis applications. The single-axis controller with a rated output current of up to 85 A controls linear and rotary synchronous servomotors as well as...
Abolished the encoder
With the LeanMotor, Stöber is launching a new drive solution on the market that completely dispenses with the position-generating encoder. The motor is also significantly lighter and smaller than an asynchronous drive and cheaper and more robust...
Rummager
Precise and energy-efficient
With the fourth generation of the PH series, Stöber is presenting precision planetary servo gearboxes which, according to the company, are the largest on the market in their performance class.
