Waycon
Use in the low temperature range down to -25 °C
As the successor to the UFA series, the ultrasonic sensors in Waycon's UFA2 series offer improved linearity (<0.4 % compared to <1 %) with the same measuring range of 20 to 200 mm.
© Waycon
Unlike their predecessors, the UFA2 sensors can also be used in the low temperature range down to -25 °C.
The nickel-plated brass housing with M12 thread enables quick installation and protection class IP67. The ultrasonic sensors are available as distance sensors with analog output (0 to 10 V/4 to 20 mA switchable) or as proximity switches with switching output (NPN/PNP, normally closed/ normally open switchable).
According to Waycon, two variants are available: with the focus beam variant, the sound beam of the sensor is particularly narrow, allowing the sensor to measure in narrow tubes such as bottle necks. In the chemical-resistant variant (CP), the membrane of the sensor is coated with a thin PTFE film and the front is protected with a PVDF attachment. This makes the front part of the sensor resistant to most chemicals.
In addition to these variants, the standard version can also be fitted with the radial beam accessory. This deflects the sound beam by 90° and eliminates the blind area.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our newsletter and keep your finger on the pulse of automation. Stay up to date with us. We provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
Click here to subscribe.
Vega
No need for cabling
Vega is launching the self-sufficient 'Vegapuls Air' radar sensors on the market in early 2021. Product Manager Clemens Hengstler explains what makes them so special.
Sick
Scans an area of up to 200 m²
With the 'TiM2xx' product family, Sick is expanding its range to include 2D LiDAR sensors for localization and anti-collision applications. The TiM240 is the first variant in the series and complies with protection class IP65 for indoor use.
Pepperl+Fuchs at SPS Connect
Kanban 4.0
With an intelligent combination of optical sensors, identification systems and modern, process-oriented cloud software, Kanban-controlled production and material flows are raised to a fully digital level.
Leuze
Two principles in one device
According to the manufacturer, the GSX combination fork sensor from Leuze combines the advantages of the light and ultrasonic versions and is particularly suitable for labeling machines in the packaging industry.
Pepperl+Fuchs
Safety portfolio expanded
Pepperl+Fuchs is expanding its portfolio for factory automation by acquiring the 'USi' safety ultrasonic sensor from Mayser, the 'world's only' ultrasonic sensor with safety certification in accordance with EN ISO 13849 Category 3 PL d, according to...
