Baumer
Temperature-resistant up to +140 °C
The PAC50 process sensor from Baumer measures conductivity in the smallest of spaces and is therefore particularly suitable for small production systems, for example in the food and pharmaceutical industries as well as in industrial applications.
© Baumer
The sensor is the 'little brother' of the 'AFI4/5' with a 60 mm long sensor housing, the display has been limited to 32 mm x 25 mm. Thanks to the one-piece design of the sensor tip, it is less affected by large and frequent temperature fluctuations. The sensor even works at temperatures of up to +140 °C. As the sensor tip is made entirely of the high-performance plastic polyether ether ketone (PEEK), it is extremely resistant to chemicals. The H version of the PAC50 is therefore suitable for CIP. The sensor housing is made entirely of stainless steel and all parts are laser-welded. In the H version, the Baumer sensor complies with the EHEDG hygiene standard for the food, beverage and pharmaceutical industries and is 3-A certified. All materials in contact with the media are FDA approved. The sensor is equipped with IO-Link as standard.
Baumer
Optimal use of IO-Link
The Baumer Sensor Suite is a PC software for the development and use of smart sensor solutions. Its intuitive operation and graphical representation of sensor functions make it easier to evaluate, select and parameterize IO-Link devices.
Baumer
The all-round view
Rotationally symmetrical objects in the pharmaceutical, food and beverage industries are often rotated once around their own axis during inspection and the images captured in the process are compiled afterwards. An alternative is a system with four...
Sick
Award for sustainability management
Sick has received a platinum medal in the EcoVadis sustainability ranking. This puts the provider of sensor-based automation solutions in the top 1 percent of more than 130,000 companies worldwide that have been assessed over the past twelve months.
