ipf electronic
Switching amplifier in M12 plug connector
With the 'IVA0012T', ipf has a connection cable with an integrated switching amplifier in the M12 connector in its range. The solution was specially developed for inductive sensors that can be used in an extended temperature range.
© ipf electronic
While the sensors from ipf are located directly at the location with the increased temperatures when used in areas with increased ambient temperatures of up to +230 °C, the connection amplifier is installed in a less thermally critical area to protect the electronics. System solutions generally consist of four components: the pluggable sensor, the pluggable connecting cable to the amplifier, the amplifier or evaluation unit and the connecting cable to the control unit. The 'IVA0012T' eliminates the need to install an amplifier as a separate module, as this is already located in the M12 plug of the connection cable. In addition to the M12 plug connector with integrated switching amplifier, the 10 m long, double-assembled connection cable has a temperature-resistant Lemo plug on the sensor side for connecting an inductive sensor.
The "living" e-paper
Screen Edition 2024
Welcome to the first issue of the 'Screen Edition', which opens up a completely new way of reading and informing yourself: With the Screen Edition, we offer you a dynamic and always up-to-date source of information with its finger on the pulse.
Kistler
Solid sales development in 2025
The Kistler Group generated sales of 424 million Swiss francs in 2025. With a currency-adjusted decline of 1 percent, or 5 percent in Swiss francs, the company was able to keep sales stable compared to the previous year.
