Micro-Epsilon at the SPS 2025
High-performance LED micrometer
The 'Optocontrol 2700' is a compact high-performance LED micrometer from Micro-Epsilon which, according to the manufacturer, offers precision, a high measuring rate and easy handling.
© Micro-Epsilon
Two models with measuring ranges of 10 and 40 mm cover a wide range of applications in automation and quality assurance. The active tilt correction enables precise detection of objects, even if they are tilted by up to 45°. Configuration is carried out via an intuitive web interface, which enables the setting of video signals, filters and various measurement modes. In set-up mode, a shadow image supports the precise alignment of the measurement object. The system is insensitive to ambient light and is also suitable for difficult environmental conditions and for measuring transparent or reflective objects. Furthermore, the large measuring distance enables flexible integration into various applications. The LED micrometer is used in quality assurance and machine monitoring.
Hall 7A Stand 130
Kistler
Solid sales development in 2025
The Kistler Group generated sales of 424 million Swiss francs in 2025. With a currency-adjusted decline of 1 percent, or 5 percent in Swiss francs, the company was able to keep sales stable compared to the previous year.
