Measurement and control technology
Michael Brosig | Inka Krischke,
Smart sensors 4.0
Sensors for the smart factory must be able to do more than just reliably record and transmit measured values. How do industrial measurement and control technology companies meet the requirements of Industry 4.0? One example.
© Jumo
For companies in the field of industrial measurement and control technology, the topics of 'horizontal and vertical integration' offer particularly interesting starting points when it comes to Industry 4.0. The former is primarily about improving communication at fieldbus level: sensors must become 'smart' and be able to do much more than just reliably record and transmit measured values. For example, electronics integrated into the sensor not only simplify commissioning and calibration on site, they also make it possible to record and evaluate the entire life cycle of a sensor. Recording and comparing all this data in an industrial cloud can provide important insights for future sensor developments in the next step. But what characterizes such a smart sensor?
One fact always remains the same with physical sensors: the actual sensor element in which the physical or chemical measured variable is recorded is and remains an analog piece of technology that follows the physical properties of its measuring principle. It is only through the further processing and amplification of the analog signal in an electronic system that the physical effects are turned into usable measured values. But is that already 'smart'?
Even if the physical signals are converted in digital electronics, nothing 'smart' has happened apart from another form of signal conversion. However, if such sensors are connected to modern but separate measuring amplifiers, additional functions can be implemented: processing several sensors, performing calculations, monitoring plausibility, generating error messages, sending messages and even transmitting data to the internet or a cloud.
No Industry 4.0 without smart sensors
The system structure of 'Digiline': sensors for different measured variables can be connected to smart networks using so-called 'hubs'. This saves time during cabling and commissioning.
© Jumo
In the new generation of 'smart' sensors - thanks to the ever-increasing integration density of electronic components and the increased computing power of even the smallest microprocessors - this additional work of the measuring amplifier is moved closer to the original analog sensor element or integrated into the mechanical body of the sensor.
The advantages are obvious: less wiring is required, possible measurement errors are minimized and there is no need for special measuring amplifiers for each measured variable. Instead of analog measured value transmission, digital interfaces can now also take over communication at the sensor.
Such a 'smart' sensor becomes an independent system component. If its firmware - the sensor software - is designed accordingly, it stores its individual calibration data, its stress data (i.e. minimum and maximum values) and limit value violations, it performs calculations and linearizations and, if necessary, even reports possible errors in advance. In bus systems, such a sensor can register itself automatically in the system and be replaced more easily. Such independent and predictive action by the sensor can certainly be described as 'smart'.
Digital networks for liquid analysis
Two examples illustrate how Jumo implements the topic of 'smart sensors' in practice.
The first example - the 'Digiline' system developed in-house - comes from the field of liquid analysis. As a bus-compatible connection system for digital sensors, it enables the creation of intelligent sensor networks. This means that all important measurement parameters for liquid analysis can be measured with just one system. The highlight here is that the Digiline pH and ORP sensors are supplied as a unit consisting of a sensor with reusable electronics. Only when the pH or redox component is finally worn out is the connection disconnected and the electronics can continue to be used with a new sensor.
The Digiline sensor network extends the number of sensors that can be connected to the 'Aquis touch' multi-parameter measuring and control devices. In addition, the sensors can be integrated directly into the 'mTron T' automation system from Jumo, i.e. without an additional transmitter.
A wide variety of sensors can be connected together in a star or tree structure; only a single digital signal line then goes to an evaluation unit or controller. This enables efficient and fast cabling of systems in which several parameters need to be measured simultaneously at different points.
As most Digiline sensors are also available with a 4 to 20 mA analog output, it is also possible to integrate the smart sensors into older systems.
Thanks to the DSM (Digital Sensor Management) software included with the system, the necessary parameterization and calibration of the pH or ORP probe can be carried out in the laboratory using a PC or laptop, a USB interface converter and the Digiline software. Calibration data and the evaluation of the sensor status are stored directly in the sensor and enable complete documentation over the entire life cycle.
The IO-Link approach
Sensors for pressure and temperature with IO-Link interface: These digital sensors can be easily integrated into fieldbus systems and therefore make an important contribution to horizontal integration in the context of Industry 4.0.
© Jumo
The second example is IO-Link: Jumo offers two sensors with an IO-Link interface for the measured variables of temperature and pressure. The standardization of IO-Link includes both the electrical connection data and a digital communication protocol via which the sensors and actuators exchange data with an automation system. A 3-wire connection with an M12 plug connection enables the simple integration of IO-Link sensors into established fieldbus systems and thus communication at the lowest field level.
IO-Link system architecture: An IO-Link system consists of an IO-Link master and one or more IO-Link devices, i.e. sensors or actuators.
© Jumo
The 'dTrans p35' pressure sensor covers a measuring range from -1 to 600 bar. The accuracy at +20 °C ambient temperature is 0.5 % of the measuring span, the long-term stability is less than 0.2 %. The temperature sensor 'dTrans T1000' works with a Pt1000 elementary sensor, its measuring range is between -50 and +260 °C. Both sensors have switching functions such as switching point, adjustable hysteresis, switching delay or window function.
The two sensors with IO interface can be configured with identical software and have various process connections. Using the supplier's Peka process connection adapter system, for example, the pressure sensor also works in the pharmaceutical and food industries - for example in beverage filling systems.
However, even the most intelligent sensor is useless without a higher-level control system that processes the data supplied. This 'vertical integration' is primarily about improving communication from the fieldbus level to the control level.
Networked without limits
With the constantly growing number of sensors, 'classic' control technology quickly reaches its limits. This is why automation solutions are required that combine simple operation with scalability. This enables users to develop customized and future-proof applications for their problems - without in-depth programming knowledge.
The demand for simple modular automation systems, such as the mTron T system, has been growing steadily for years across all industries. This modular system uses an Ethernet-based system bus and an integrated PLC. The measuring, control and automation system with its application-oriented and user-friendly configuration concept has a central processing unit with a process image for up to 30 input/output modules at its core. The CPU offers higher-level communication interfaces including a web server. For individual control applications, the system has a PLC (Codesys V3), programmer and limit value monitoring functions as well as math and logic modules. A multi-channel controller module, analog input modules and a freely configurable digital input/output module with twelve channels are available as input/output modules. This means that different process variables can be precisely recorded and digitized with the same hardware, which simplifies planning, scheduling and warehousing - with the corresponding cost benefits.
Author: Michael Brosig is press spokesman at Jumo in Fulda.
Jumo
Millions invested in new plant
The Jumo Group officially opened the new Plant 2 ('Sensilo') in Rodges near Fulda on May 22, 2025. At around 48 million euros, the new building is the largest investment in the company's history. In addition, around 21 million euros will be invested...
