Baumer
Sensors with memory
Condition monitoring is one of the current trend topics in the industry. Baumer relies on IO-Link and presents inductive sensors with the "most comprehensive diagnostic data on the market" according to the manufacturer.
Condition monitoring made easy thanks to fully digital inductive sensors with extensive diagnostic data and IO-Link interface.
© Baumer
In addition to the sensor temperature, operating voltage and operating time, the sensors record the number of boot cycles, the switching frequency and the distance values. This information can be called up via the IO-Link interface if required and can be digitally processed directly in the control system. The sensors also have a memory: their histogram function enables the frequency distribution of the process and diagnostic data to be evaluated over a relevant period of time. In this way, information on the condition of machines and systems can be collected and evaluated for the purposes of condition monitoring. This data forms the basis for a predictive maintenance concept; specific analyses of the collected diagnostic and process data can be used to increase system effectiveness and optimize processes.
The 'AlphaProx' inductive distance sensors primarily provide a digital distance value accurate to the micrometer. With a cycle time of 0.6 ms and a switching frequency of 1.25 kHz, the inductive sensors are the fastest on the market, according to the supplier. The extensive diagnostic data mentioned above is a new addition: For example, the age of the sensor can be determined very precisely with the help of the number of boot cycles recorded or the operating time to date, enabling machine operators to draw forward-looking conclusions about when a component needs to be replaced or serviced.
The histogram function for logging process and diagnostic data makes it easier to trace faults in the event of undesirable machine states, thus shortening the fault analysis process. It is also possible to evaluate trends. For example, an increase in the sensor temperature can indirectly indicate that a machine component near the sensor is heating up too much or that the immediate ambient temperature is rising. This can be an early warning of an impending machine standstill.
In addition to the temperature values and the voltage supply, the measured distance and frequency values are available for evaluation as a histogram. The statistical data can be reset at any time so that the statistics in the process are not distorted during sensor commissioning or replacement. Via the IO-Link interface, every system manufacturer can read out the data for their histogram evaluation intuitively and as required. There is also no need for laborious conversion of units, as the sensor already processes this internally and outputs it in the desired unit.
Most of this diagnostic data is also available for the Baumer ultrasonic sensors'UR18' and 'U500'.
OPC UA
On the way to the world library
The vision has been in place since the end of 2014: OPC UA is to achieve the status of a globally recognized standard for the Industrial Internet of Things IIoT by 2019 at the latest. During the press conference at SPS, the Foundation took a stand...
Turck
More investment in software expertise
The economy is leaving its mark: compared to the previous year, Turck expects total sales of around 640 million euros for the 2019 financial year, a decline of 3%. Nevertheless, Managing Director Christian Wolf is optimistic.
SPS 2019
A look back at the fair
The 30th SPS was the highlight of the automation industry at the end of November. The keywords 'digitization' and 'digital transformation' were visible right through the halls. The main trends can be seen in the film below.
Video
SPS 2019 in retrospect
The 30th SPS, the trade fair highlight of the automation industry, took place at the end of November. The buzzwords 'digitalization' and 'digital transformation' were visible throughout the halls - the most important things in the film.
Sieb & Meyer
Dynamically driving high speed motors
Under the name SD4x, Sieb & Meyer is developing a new generation of frequency inverters for high-speed applications. The first of these is the SD4S version, which is designed for small high-speed spindles and motors with a power output of just a...
IniNet Solutions
Industry 4.0 'off the shelf'
iniNet Solutions has developed an automation architecture based on web server-supported SCADA and programming software, which is intended to bring manufacturing companies more easily than ever to industry 4.0 level. This architecture can be seen at...
CloudRail
Plug and play into any cloud
A year ago, Cloudrail unveiled the 'CloudRail.Box' for the first time - a gateway that connects plug-and-play to IO-Link sensors and masters and sends the data to any cloud platform. Now it also handles OPC UA and Edge Computing.
