Stallion
Position measurement in confined spaces
The 'Acuro AM34' absolute encoder from Hengstler has an installation depth of less than 20 mm and therefore enables the design of servomotors with very small dimensions.
© Stallion
With a positioning accuracy of ±120 angular seconds, the encoder from Hengstler is particularly suitable for use in servo drives. It is bearingless and therefore generates hardly any intrinsic heat, meaning that servo motors with these encoders can be operated in the highest speed range, according to the supplier. The resolution of the encoder is 16 to 20 bits in the singleturn version and 12 bits in the multiturn version. The operating temperature range is specified as -40 to +120 °C. The absolute encoder is designed for speeds up to a maximum of 12,000 rpm and has a BiSS/SSI interface for digital automation. As the encoder also has an electronic data sheet (EDS), servomotors can be installed by the user within a short space of time. For drive technology manufacturers, integrating the rotary encoder into their motors is also very easy thanks to the large mounting tolerances (±0.5 mm axial, ±0.1 mm radial).
The "living" e-paper
Screen Edition 2024
Welcome to the first issue of the 'Screen Edition', which opens up a completely new way of reading and informing yourself: With the Screen Edition, we offer you a dynamic and always up-to-date source of information with its finger on the pulse.
Sick
Sales growth in a turbulent market environment
Thanks to innovations and a focus on strategic industrial markets, Sick was able to moderately increase its sales in the 2025 financial year. In a turbulent market environment, the company was able to maintain its position and gain market share with...
