Baumer
No chance for dirt, dust or liquids
The contactless 'EB360R' from Baumer is a multiturn encoder for mobile machines that works maintenance-free in harsh environments, making it suitable for construction vehicles, work platforms or agricultural machinery, for example.
© Baumer
The bearingless magnetic encoder from Baumer relies on a contactless scanning principle with a sensor and separate magnetic rotor. The angular position and the number of revolutions are determined without moving parts inside the sensor. The sensor unit is mechanically and thermally decoupled. Unlike classic rotary encoders, there is no shaft inside the encoder. The sensor electronics are completely encapsulated and do not allow liquids or dust to enter. Extra protection against shocks and vibrations is provided by the encapsulated electronics inside the corrosion-resistant plastic housing. The sensor has a housing height of only 22 mm when installed.
Baumer
AI quality inspection made easy
AI will also bring fundamental changes to industrial applications. What is interesting is the gap that is opening up between this realization and practice. Although most companies see the potential of AI, only a few dare to use it.
In focus: Agriculture
The e-paper of issue 05/2024
Strategies for the future are one of the topics covered in the current issue of Computer&Automation. Read about the reforms that associations are demanding from politicians, the opportunities offered by technologies such as ChatGPT and SPE and...
The "living" e-paper
Screen Edition 2024
Welcome to the first issue of the 'Screen Edition', which opens up a completely new way of reading and informing yourself: With the Screen Edition, we offer you a dynamic and always up-to-date source of information with its finger on the pulse.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
