a.b.jöddenWorking at temperatures from -40 to +120 °C
A.B.Jödden offers inductive displacement transducers and fine probes for measuring displacements of up to ±10 mm with resolutions in the µm range. The plunger of the fine probes is pressed into the rest position by an integrated spring or, in the case of larger measuring travels, by an external spring.
1 of 15
compmall industrial PCs
© compmall
Robust industrial PCs for smart robotics solutions
- CPU: Vortex86, Atom, Celeron, iCore, Xeon
- Network connection: 2.5 and 10GbE, PoE, Wi-Fi 6E, Bluetooth
- Interfaces: RS.232/422/485, USB 3.2, CAN bus, PC/104, M.2
- Temp: -40°C - 85°C, TPM, MIL-STD 810, UL & c-UL
Embedded PCs | Panel PCs | Embedded Boards
More information here.
1 of 15
