Product innovationsNews from the field of sensor technology
In the smart factory of the future, nothing will work without sensor technology as the 'bottom floor'! Sensor technology remains indispensable as the basis of industrial production systems. Computer&AUTOMATION presents current trends in the field of sensors in a series of images.
Synotech has added the model M607M83 to the robust ICP/IEPE vibration sensor models 'M607A11 Swiveler' and 'M607A61 Spindler'. Its internal sensor electronics are designed in 3-wire technology, enabling it to be supplied with a direct voltage of 3 to 12 V(DC). The sensor measures in the frequency range from 1.5 to 10,000 Hz with a sensitivity of 100 mV/g. It is supplied with a 1-point calibration at 100 Hz. The 'Swiveler' technology facilitates the installation of the industrial vibration sensor with IP68 protection: there is a union nut above the sensor base which is screwed onto the mounting bolt. The 3 m long integrated connection cable does not have to be rotated around the sensor axis, but can be freely aligned.
