Current productsNews from sensor technology
What would the smart factory of today and tomorrow be without sensors? Sensors are indispensable as the basis of every industrial production system. Computer&AUTOMATION has summarized current trends in a picture gallery.
Disynet has designed the 7010 liquid level sensor specifically for environments where monitoring of a variety of liquid types is required. It uses capacitive technology to detect the level of the liquid in question. There are no moving parts, floats or other mechanical connections. Equipped with IP66/IP68 protection, the sensor operates in liquids such as water, saline solutions, fuels, oils and chemicals (others on request) at temperatures from -40 to +125 °C, ±2 % accuracy of nominal range at 20 °C. Available in lengths up to 2 m, the sensor offers two output options - analog voltage or current. Manufactured from 316 stainless steel, it is corrosion resistant even in harsh environments.
