Nanotec Electronic
Encoder for motors from size NEMA 8
Nanotec is expanding its product range to include the compact NME3 magnetic encoder. Thanks to its modular design, it can be combined with a wide range of brushless DC and stepper motors from size NEMA 8.
© Nanotec Electronic
With a maximum speed of 30,000 rpm, the compact singleturn absolute encoder from Nanotec is particularly suitable for applications that require precise speed control. As its magnetic scanning is insensitive to dust, shocks, vibrations and high temperatures, it delivers reliable measured values even in harsh environmental conditions. The encoder is available in two versions: for incremental signals with a maximum resolution of 4,096 CPR or with an SSI interface and 16-bit resolution. The incremental version also generates Hall signals for BLDC motors. Two different sizes cover a wide range of motors and shaft diameters of 4 mm, 5 mm and 6.35 mm.
Nanotec
Management increased
Nanotec is expanding its management team: CEO Stephan Huber and Chief Technical Officer Dr. Christian Hainzlmaier will manage the electronics company together with Elke Zec, Chief Financial Officer, and Durmus Özcan, Chief Sales Officer.
Nanotec
High-torque gearbox in three sizes
With the 'GP42', 'GP56' and 'GP80' series, Nanotec offers high-torque planetary gearboxes in three sizes. According to the manufacturer, the compact modules can be easily adapted to individual requirements and have a long service life.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
