Baumer at the SPS 2023
Easy positioning and inspection
Using profile analysis, the 2D profile sensors of the 'OX' series from Baumer can solve positioning and inspection tasks in assembly and handling technology.
© Baumer
Baumer sensors can be used wherever OK/NOK inspections or positioning tasks are possible by evaluating height information. A set of tools enables the complete processing of profile data directly in the intelligent sensor. It transmits the X/Z position value to the controller with a precision of up to 5 µm without any further external steps. The sensor class can be connected with just one cable thanks to Power over Ethernet (PoE). It is operated via the integrated web interface. Up to seven measuring tools can be freely configured there with graphical support. Live visualization of the measurement tasks is also possible in the web interface. Settings in the sensor can be checked, adjusted and optimized directly. Measuring ranges of up to 500 mm with a field of view of up to 300 mm ensure design freedom for numerous applications.
Hall 4A, Stand 345 + 351
AMA Association
Slight decline in incoming orders
The sensor and measurement technology sector recorded no change in turnover in the third quarter of 2024 compared to the previous quarter. However, turnover fell by 10% compared to the third quarter of 2023. Incoming orders were 2% below the level...
Most read
The top articles in June 2024
The most-read articles in June illustrate the power of the automation industry. Read more about the technologies and strategies that are gaining ground in areas such as networking, robotics, safety and the process industry.
Avnet
New president at Farnell
Avnet has appointed Rebeca Obregon as the new President of Farnell, an Avnet company, effective July 1, 2024. Farnell is a high-service distributor of electronic components.
