Balluff
Dolphins as role models
Balluff uses the 'BFD' ultrasonic position sensor to monitor hydraulic clamping elements. The technology is based on the echolocation system of dolphins, which send ultrasonic waves into the water and are thus able to form a spatial image of their surroundings.
© Balluff
The ultrasonic sensor from Balluff emits ultrasonic waves into the hydraulic fluid of short-stroke clamping elements such as swing clamps or block cylinders and uses the ultrasonic waves to directly detect the respective clamping process and the clamping status. Possible deviations in the oil supply, casting errors, contour differences or deformed workpieces can thus be detected at an early stage. The position sensor measures over the entire measuring range (0 to 80 mm), offers a repeat accuracy of ±50 μm and a linearity deviation of ±250 μm. Other features include pressure resistance up to 350 bar, IP67 and an operating temperature of 0 to +85 °C. In IO-Link operation, the sensor provides status data on signal quality or device temperature and detects critical changes such as air or particles in the hydraulic system.
Balluff
Condition monitoring in the sensor
Whether conveyor belt, industrial robot, hydraulic unit, motor or pump - the failure of individual components can bring the entire system to a standstill. This makes condition monitoring all the more important - for example using a condition...
Balluff
Capacities in China expanded
Balluff can double its production volume at the Chengdu site. The basis for this is a new 6,000 m² building, which will increase the production area by 75% in order to serve the APAC market.
