Manner
Accuracy improved
Manner is launching the Xtrema 2.0 torque sensor with improved accuracy. With an overload rating of 400 %, it can measure both continuous loads and short-term load peaks in dynamic operation.
The Xtrema 2.0 torque sensor from Manner
© Manner
Thanks to the short design with low rotor weight and low mass moment of inertia, nominal speeds of up to 30,000 min-1 can be achieved. As an option, the flanges can be operated in a temperature range from -40 to +160 °C. According to Manner, another special feature is the electronic compensation of the zero point error Tk0 and the pitch error Tkc, which enables a consistently high level of accuracy to be achieved regardless of the ambient temperature. The DIN flange pattern used, which is compatible with HBM torque sensors, allows easy integration into new and existing test benches with existing infrastructure. The flange pattern of all measuring ranges is retained.
AMA Innovation Award 2025
Submit applications now
The AMA Association for Sensors and Measurement (AMA) is calling on scientists and developers from industry and research to apply for the AMA Innovation Award 2025. We are looking for research and development results in sensor and measurement...
Janitza
Management expanded
Axel Hessenkämper joined Janitza as the new Chief Executive Officer (CEO) on September 1, 2024 and is part of the management team alongside Mr. Janitza, Mr. Müller and Mr. Veidt.
