Mushroom
Navigate safely and autonomously
Pilz offers manufacturers a safety solution in accordance with ISO 3691-4 for freely navigating mobile platforms.
© Mushroom
The solution consists of the safe small controller 'PNOZmulti 2' from Pilz with new functionalities for synchronization monitoring and control of the safety laser scanners 'PSENscan', which provide area monitoring. In addition, the industrial firewall 'SecurityBridge' offers protection against unauthorized access from outside. The function blocks for synchronization monitoring in the 'PNOZmulti Configurator' software tool of the safe small controller can be used to reliably monitor the synchronous operation of the axes of an AMR. The program function compares the encoder values of the two axes with each other, allowing conclusions to be drawn about the direction of movement of the mobile platform. This information can be used to dynamically implement the safe zone switching required by the standard in the PSENscan safety laser scanner. This is made possible by a 'PSENscan' function module: with the 'zone selection function', up to 70 protective fields can be switched over dynamically.
Pilz at the SPS 2023
On the safe side
The EU Machinery Regulation 2023/1230, successor to the previous Machinery Directive (2006/42/EC), is here! Pilz provides information in the form of an expert panel on what it means for machinery manufacturers and distributors.
Mushroom
Change in the legal situation
Standards and directives provide global guidance on how products, machines and systems should be designed, manufactured and used safely. Digitalization and networking are changing the standards landscape, and the focus is shifting to industrial...
Bihl+Wiedemann
Innovation partner for automation
Bihl+Wiedemann is a medium-sized, owner-managed company - founded in 1992 by Jochen Bihl and Bernhard Wiedemann in Mannheim. It develops and manufactures complete solutions for functional safety and data communication in machines and systems.
EUCHNER
Customized solutions for smart automation
In a world of increasing automation, functional safety is essential. Plant operators not only have to comply with legal requirements, but also ensure efficiency and availability. For more than 70 years, EUCHNER has been supplying customized...
