Safety gate protection
Xabier Antolin | Lukas Dehling,
Modular and secure
Increasingly complex applications require increasingly flexible system components - including safety gate protection. With a modular system, users can adapt their solution to individual requirements.
© Euchner
Achieving more with less - that was the guiding principle behind the development of the MGB2 Modular safety gate system. Or - to put it in more detail: With fewer components, the second generation of Euchner's globally successful Multifunctional Gate Box should offer more flexibility not only to machine builders, but above all to users. And what's more: more networking options, more functions, more efficiency and, at the same time, more scope for future innovations around the safety gate, including in the direction of Industry 4.0.
With the MGB2 Modular safety gate system, submodules with operating elements are simply plugged into the locking module.
© Euchner
The special feature: the system has a modular design. This means that the actual locking module is structurally separate from the bus module with integrated Profinet/ Profisafe. The submodules with the corresponding operating elements, such as pushbuttons, selector and key switches or emergency stop buttons, are plugged into the locking module according to the requirements.
Remote mounting of bus and submodule is also possible.
© Euchner
The separation of the locking module and bus module offers two important advantages: Up to six guard locking modules can be connected to just one bus module. So if, as is often the case in practice, a bus is to collect the signals from two or three safety gates, two or three bus nodes were previously necessary - with the 'MGB2 Modular', just one is sufficient. And in addition to the devices themselves, the user saves network cables, network addresses - and ultimately also memory capacity in the control area: a commodity that is becoming increasingly expensive, not least in view of the intelligent factory of tomorrow. Another advantage: the bus module and function module can be mounted separately. This allows installation at any suitable point on the machine, especially where space is limited.
However, flexibility is guaranteed above all by the individual submodules: This is because they offer the possibility of a large number of customized combinations. A total of up to 18 devices (modules or submodules) can be connected to each MGB2 Modular.
A locking module, for example, is one participant, a submodule with two pushbuttons is another and a submodule with an emergency stop is a third. The bottom line is that the new modular concept can be used to implement hundreds of variants with just a few submodules for door interlocks and associated systems alone.
System with four safety gates
Here too, a look at a typical application example illustrates the flexibility and efficiency of the new multi-talent 'on a living object', so to speak. Let's take a system with four safety gates as an example: the operator should be able to start and stop certain processes at two of them; at all of them, it must be possible to acknowledge a fault, inform the system that they want to enter it and reactivate guard locking. Previously, this required four complete MGB systems. With the new safety gate protection, only a single bus module and four guard locking modules are required to perform the same task. The buttons required to implement the above-mentioned control functions are put together using different submodules.
What does this wide range of variants with just a few components mean for the user? On the one hand, he can significantly reduce his stock of spare parts and no longer has to deal with countless different article numbers. On the other hand, conversions to the machine are much easier, which is certainly a big plus point for many companies in view of the ever-increasing pace of product innovation in manufacturing companies.
For example, if users want to integrate an additional pushbutton into the system, they only need to add the appropriate submodule and not the complete locking module. Replacing individual components is also much easier and cheaper in the event of a defect - in most cases even while the system is in operation.
In addition to the possibility of hot-plug replacement and the permanent provision of diagnostic information for the control system, the general ease of repair of the MGB2 Modular components helps to avoid or at least significantly reduce downtimes. For example, all screws are captive and can be tightened or loosened with a single tool.
The VPN network
The new safety gate protection system offers the option of networking within a virtual private network (VPN), particularly for larger companies with several plants. Employees are therefore able to monitor the functionality of all their safety gate systems in all production plants in real time from the head office via a web server. In the same way, they receive complete log files at any time, which they can send to Euchner's support team in the event of any irregularities in order to identify the problem as quickly as possible.
For security reasons, however, remote access only allows information to be retrieved; changes to the configuration or maintenance work are not possible in this way. The web server can also be completely deactivated with a simple toggle switch. This type of master switch is important because there are still many companies that do not allow remote access.
Equipped for the future
But regardless of whether the information from the devices is to be accessed remotely or on site or analyzed in a cloud: What data does the MGB2 Modular actually provide? The devices can already read out a wide variety of values - from temperature to voltage development, for example. At the moment, this is not very useful for day-to-day work - unless you are specifically looking for the cause of a problem that only occurs in summer or that could be related to temporary voltage fluctuations. However, this is likely to change very soon with a view to Industry 4.0. It is not yet possible to predict in detail what data users will need in the smart factories of the future, but the solution was initially designed for pretty much all types of requirements.
Speaking of the future: the modular structure also creates good conditions for the development of additional innovative features and functions for the second-generation Multifunctional Gate Box. Because one thing is clear: a single submodule can be designed and implemented more quickly than a complete secure system for the safety gate. The only fixed points are the design with the corresponding dimensions and the standardized plug connections - what exactly happens on this platform is decided by technological creativity.
Author:
Xabier Antolin is Product Manager at Euchner.
Circuit breakers
The transparent power supply
Transparency in the production process requires the continuous recording of measured values and their forwarding to the control systems. The example of a modern automatic circuit breaker shows what this can look like in the field of 24 V (DC) power...
Industry 4.0
The 'SEAP 4.0' project
I4.0 has been accompanying automation technology since 2011. The main results of this work are the Reference Architecture Model Industry 4.0 (RAMI 4.0), the I4.0 component and the asset administration shell. The concept of the asset administration...
Smart cameras
Optimized production
Covering three tasks with just one visualization system - this was the requirement when redesigning a bag filling system for the food industry. Smart camera technology makes it possible.
Control software / simulation
Automate the test
Machine and system manufacturers are increasingly moving towards simulating control software before commissioning in order to correct any errors in advance. Instead of carrying out the tests manually as before, it is advisable to switch to an...
Industry 4.0
From the sensor to the cloud
How can sensor data be uploaded to a cloud platform? At SPS IPC Drives, Hilscher is presenting a technology platform that is intended as a system solution for OEMs and also includes the aspects of diagnostics and maintenance.
Industry apps
Digital prototyping
Digitization projects are often viewed with scepticism. This makes it all the more important to involve employees in new workflows and processes right from the start. Rapid prototyping methods and processes are suitable for this - for example when...
Safety mats
Operation by foot
Safe area monitoring combined with active machine operation - this is exactly what a dynamic safety mat offers. Workers can trigger defined actions using their feet and virtual buttons. Their hands remain free, enabling new operating concepts.
Industrial PCs
20 % more productive
Flying chips, vibration and splash water: industrial PCs have to cope with such influences in the production of clamping tools. With BDE and CAD software on board, they increase productivity by 20 %.
