Schmersal at the SPS 2022PL d easily accessible
Schmersal has launched new variants of the multifunctional SRB-E series of safety relay modules.
Lütze has added the compact, single-channel Locc-Box-M, which can be used as a stand-alone version, to the proven Locc-Box family of electronic load monitors. It can be used to selectively adjust the load using five patented, analog trigger characteristics ranging from 'fast' - for sensors, for example - to 'super slow' for motors and fans. According to the manufacturer, load monitoring is therefore suitable as a replacement for circuit breakers in an existing setup. The required current range can be individually set in 1 A increments within a bandwidth of 1 to 8 A. The up to 40 possible setting variants can be fixed using a lead seal. The load monitor can be used via plug-and-play without additional modules. With an installation depth of just 86 mm, an installation height of 92 mm and a width of 8.1 mm, it is suitable for installation in smaller switch boxes as well as the classic installation in switch cabinets. The LED status display uses green and red signaling to indicate operating states and errors in the load circuit.
SPS 2022: Hall 9, Stand 311
