Euchner
Focus on small flaps and doors
The safety systems integrated into systems or machines must be designed in such a way that they do not interrupt production processes and keep system productivity at a high level. What can transponder-coded guard locking do?
© Euchner
The type of safety technology, including the required performance level, that must be used in machines and systems is determined by the Machinery Directive and binding standards such as EN ISO 13849-1 and EN ISO 14119. These standards determine when, for example, guard locking with or without transponder coding should be selected.
On the one hand, guard locking devices provide personal protection: they ensure that people are not put at risk during subsequent, dangerous movements. On the other hand, they protect the process, as guard locking effectively prevents employees from simply opening guards, which would lead to machine downtimes and thus to a loss of productivity.
To avoid unnecessary downtime from the outset, machine manufacturers are increasingly using guard locking devices, even if they are not required in some cases in accordance with EN ISO 14119. The installation of a transponder-coded guard locking with a high level of protection can also be the right choice after a machine has been converted or retrofitted - for example, to meet the updated requirements of a risk assessment and thus be able to continue to produce safely in the future. Guard locking devices with transponder coding offer a high level of protection against tampering.
If small doors and flaps on machines are to be safeguarded with protective devices, designers often favor compact switches and safety systems - on the one hand because installation space is usually limited, and on the other hand because machine design aspects play a special role in many industries. Ideally, safety switches should therefore be able to be installed in such a way that they are almost invisible.
Inconspicuously integrated
Euchner has developed the 'CTM' series in collaboration with end users to meet these requirements. The devices are among the smallest transponder-coded switches with guard locking and, thanks to their dimensions of 120 mm x 36 mm x 25 mm, can be integrated inconspicuously into the housing or enclosure of machines. Their design makes them ideal for use in small or lightweight doors and flaps. An elastomer-mounted ball actuator also makes it possible to secure doors with small swing radii from 150 mm.
Despite its compact design, the switch offers safety gate protection to Cat. 4/PL e in accordance with EN ISO 13849-1 and therefore meets the highest level of protection for people and machinery.
In the event of a power failure or when the system is switched off, the bistable guard locking function of the guard locking always ensures a high level of protection, as the system remains in its current state in these cases: if the guard locking of the switch was previously activated, the door remains securely locked. If the guard locking was deactivated, the door can still be opened and closed again. This virtually eliminates the possibility of people being locked in unintentionally.
The system offers a high coding level. In addition, its locking force of 1000 N is sufficient for many applications. Typical applications include case packers and dosing, filling and sealing machines in the packaging industry, as well as 3D printers, blow molding machines for the plastics processing industry and smaller doors and flaps on machine tools.
Hygienically designed
Open versus closed (see image below): The flexible ball actuator of the 'CTM' series enables the smallest door radii - ideal for machines with limited installation space.
© Euchner
The guard locking offers a hygienic design for applications in the food and pharmaceutical sectors: even the basic model is designed with hygiene in mind, making it easy to clean. The housing complies with protection class IP69 and is therefore resistant to high-pressure and steam jet cleaners. In addition to the basic version, there is a special version in which only food-safe materials are used. The plastics in this version, which can be recognized by its black and blue design, comply with EU Regulation No. 10/2011 and also meet the requirements of EHEDG and FDA conformity. Thanks to its smooth surfaces, rounded edges and materials that are resistant to cleaning agents, the hygienic version is particularly suitable for the first packaging of food, medical instruments or medicines. This special version is also ideal for filling liquid personal care and wellness products or beverages.
The flexible ball actuator of the 'CTM' series enables the smallest door radii - ideal for machines with limited installation space. Here the closed state.
© Euchner
The topic of energy efficiency also plays an important role in mechanical and plant engineering. The numerous safety switches and guard locking devices that can be installed in a system line are certainly noticeable as power consumers. For this reason, designers are increasingly ensuring that the energy requirements of the integrated systems are kept within limits. The switches in the 'CTM' series
switches in the 'CTM' series, which are designed for economy, only draw 500 mA from the power supply for 70 ms when the polarity of the solenoid is reversed - not least thanks to the bistable guard locking principle. During continuous operation, it is 50 to 70 mA.
Intelligent communication functions
Ariane Isabel Walther works in the Marketing/Corporate Communications department at Euchner in Leinfelden-Echterdingen.
© Euchner
Up to ten CTM guard locking devices can be electronically connected in series in the field. The designer can also easily wire them with other Euchner devices. For example, the hot-pluggable systems can be coupled with the 'ESM-CB' safety module in order to continuously transfer process data from the
system to the higher-level control level via the IO-Link master. The safety module acts as a safety relay. At the same time, it is in constant dialog with connected devices. For each switch, it queries the system status, the ambient conditions and other details in real time. If the guard locking devices are networked with each other in this way, there are numerous diagnostic and evaluation options for system operators. In addition, the intelligent communication functions of the system network can also be used for Industry 4.0 purposes, such as predictive maintenance.
Euchner
Safety for smaller systems
With the CES-C07 safety switch and the ESM-CB safety module, Euchner has a duo in its portfolio that, according to the manufacturer, opens up new freedom in the design of safety solutions for smaller systems.
Safety switch
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
E-T-A
Sensory in view
Intelligent power distribution systems are valuable helpers when it comes to digitalization in the IT rack. Monitoring the IT racks using sensors is a particularly effective measure for increasing system availability.
Ateg
Keyboards with glass surface
Ateg offers capacitive PC keyboards with a glass surface from the French manufacturer Tactys. The glass of the user interface is made of 3 mm thick, hardened white glass, which is robust against mechanical influences.
