Genoa
Arnold Krille und Simon Daum | Andrea Gillhuber,
AI in industrial security
The complexity of communication and production networks will continue to grow. It is almost impossible for the human brain to penetrate. This is also becoming a problem for the cyber security of industrial plants. Support is coming from AI security research.
© ZinetroN / Shutterstock.com
The physical separation between IT and OT communication networks (operational technology) is no longer a modern security concept in view of smart factories, predictive maintenance and Industry 4.0. The consequence of networked environments is that attackers are increasingly finding a way into the ever more complex industrial production and process control environments. In office networks, all connections can be interrupted for a short time in the event of an attack in order to fend off the attacker. This is not possible in OT networks, as the availability of the systems is the most important thing here. This is why a different protection strategy is now gaining acceptance: The zero-trust principle 'never trust, always verify' is gaining in importance. Where previously the rule was "I can trust whoever is in my network", in future the rule must be "I don't trust anyone" (Zero Trust Network Access, ZTNA). This is particularly important for older production facilities (brownfield), which are becoming increasingly networked. Five principles are helpful here:
  • It is no longer just the central access to the network that needs to be protected. Special attention must also be paid to the target systems and the individual network assets. To achieve this, all activities in the network must be monitored and logged. In essence, it is all about prevention and early detection.
  • Transparency in the network must be improved: Which assets are in the network and which have a higher need for protection? It needs to be clarified who is allowed to talk to whom and who is allowed to do what.
  • The minimum principle must apply to identities, roles and rights. Only what is necessary is permitted.
  • Only specific services may be permitted for communication and not entire systems or even networks.
  • A fast and adaptable protection strategy is required.
These principles further increase the demands on the administration of the OT network. Because OT operators are already overburdened with the necessary rules for the network, services and assets, intelligent support is required.
Holistic, intelligent threat management
Figure 1: Overview of current market and technology trends and their impact on IT security. For example, the Internet of Things is giving rise to complex, highly distributed, dynamic communication networks.
© Genoa
In a zero trust strategy, it is no longer enough to analyze anomalies in the data stream with intrusion detection (IDS) and intrusion prevention systems (IPS). For example, if any network component sends a control command to a centrifuge, there is nothing conspicuous in the data stream itself and therefore nothing is detected. The system does not check whether this network component is allowed to send such a signal or whether this behavior is unusual. Attackers can therefore take over system components in the network without this being noticed immediately. It is therefore becoming more essential to detect and contain attacks at an early stage. This is possible by monitoring the behavior patterns of all network devices (assets) and assigning them to defined rules. To do this, it must be known at all times who is communicating with whom and which connections are permitted. In addition, different security zones help to set up a higher protection status for particularly sensitive data and systems.
The increased need for monitoring and regulation will no longer be manageable with conventional manual measures in the future. Even today, OT network operators are barely able to cope with the multitude of tasks and requirements. They also often lack the experience and time to acquire the necessary knowledge. The solution lies in intelligent systems that support OT operators and IT administrators in their tasks. Using data analytics and threat intelligence, such tools take over many manual tasks, automate activities and supplement existing firewall solutions. Genua's cognitix Threat Defender is an example of what these tools can achieve. It allows automated network monitoring to be set up and network traffic from all devices in the network segment to be analyzed using anomaly detection. The Threat Defender shows the development of traffic in real time and provides information about the applications causing it. Network analysis, intrusion detection, asset tracking and a dynamic policy engine are combined in one system.
Segment the network by function
Figure 2: The screenshot shows a section of a set of rules in 'cognitix Threat Defender'. Summarized in self-contained policies, rules that build on each other ensure order in the network.
© Genoa
With the help of an expert system and intelligent heuristics, the Threat Defender models the behavior in the network and assigns it to certain behavior patterns. Rules can then be defined by the OT operator. Once all network devices have been recorded and the behavior patterns of these as-sets are monitored, the operator can mark and tag the devices according to functions and tasks. This enables dynamic and transparent segmentation of the network and no longer just at the transition to another network segment. By tagging network components, the operator can define their security properties individually. How a device is allowed to communicate with other participants in the same network or other networks is now decided on the basis of its function and behavior. The operator can use appropriate rules to define the behavior of the network components in order to prevent unwanted communication.
It is also relevant for an OT network that the behavior of the devices can change depending on the operating status of the system. Rules can therefore include specific definitions for faults, remote maintenance access or maintenance measures. If a new unknown communication is detected by the system, it is initially suspicious and triggers an alarm. The new communication can now be automatically throttled or completely interrupted, while all known and permitted processes continue to run unchanged. Throttling an unknown communication is a particularly good way of slowing down the attack and gaining time to evaluate the communication.
Mastering the chaos in the network
The assumption that OT networks are static and practically not subject to change is no longer valid. The example of the automotive industry shows that production facilities are being adapted more and more dynamically. External services from the cloud are increasingly being integrated for monitoring and surveillance, while more and more sensors and the integration of IoT devices are further increasing the complexity of OT networks. At the same time, the requirements for network availability and performance are increasing. If OT networks change dynamically, it will be even more difficult for OT operators to keep track of and understand them in future. They will need additional support in analyzing ever larger volumes of data, evaluating alerts and selecting suitable measures. Added to this is the requirement to keep the network structure and firewall rules up to date in the face of dynamic changes.
Advanced AI (artificial intelligence) and ML (machine learning) methods can also be used to control the chaos in the network in the long term. In the Wintermute research project (see box), AI and ML-supported methods will address three key problems in the future:
  • Situation assessment - classifying system behavior and providing feedback on anomalies,
  • policy definition - individual rule creation,
  • the enforcement of security in complex networks.
The 'Wintermute' research project
The increasing digitalization of industry and the growing dynamics and complexity of communication are creating interwoven communication systems that must meet critical requirements in terms of availability and offer appropriate protection for sensitive data. Current solutions focus increasingly on the automatic detection of harmful communication patterns, require manual countermeasures and often neglect the usability aspect.
In the BMBF-funded research project 'Wintermute', researchers are using AI methods to classify system behavior and provide the administrator with feedback on anomalies. In addition to the AI-supported situation assessment, it should be possible to incorporate feedback from users in order to adapt the resulting rules to individual needs. Wintermute is also focusing on user-friendliness to enable companies to understand their highly networked systems and make them accessible for risk analysis and management. The aim is not to replace qualified specialists, who are often scarce or unavailable in this area. Instead, the aim of the research project is to provide these specialists with the best possible support for their decisions.
Genoa is taking on the role of consortium leader within the network of research partners. The project partners are the universities of Bamberg, Bremen and Würzburg. Other partners are the Federal Office for Information Security (BSI), acs plus, DB Systel, IsarNet Software Solutions, Renk and Xitaso.
Usability in particular is becoming increasingly important, as the aim is to better understand highly networked systems in order to simplify risk analysis and risk management as well as usability. The aim is to support the OT operator in defining suitable rules and security policies. AI should also help them to deal with dynamic changes in the network more easily. The research team of the Wintermute project is not aiming for an automated system for network security, but rather to create technologies that serve as support for the administrator. The main approaches within the research project are described below.
Figure 3: Wintermute project: Clustering of communication traffic with regard to local structures.
© Genoa
Creating a better overview of the network
The AI-based system is designed to help people regain a better overview of their own network. The research approach here is to view the network as a graph. This may sound banal at first, but it is not just an attempt to derive a simple network plan. Instead, IPFIX data is collected by a probe in the network, pre-processed and used as input data for machine learning algorithms. The aim is to reduce complexity for the administrator. Instead of having to deal with countless individual appliances in the network, a manageable number of clusters of similarly behaving devices are formed and visualized. A large number of features can be derived and combined from the IPFIX data for clustering. For example, assets can be aggregated on the basis of their communication relationship, i.e. the question of who is talking to whom via which protocol can be answered. However, it can also be useful to focus on differentiating between the client and server-like behavior of the assets during clustering. Thanks to the flexibility of the approach, the administrator can react to different environments and application scenarios and always gain a deep understanding of their network. The comprehensible visual representation of the clusters and their communication relationships and functionalities support the explanation of the ML results. For example, it is possible to show why systems have been grouped in the same cluster and which attribute values differentiate clusters from one another.
Creating rules for network clusters
In the next step, clustering and the communication behavior of assets derived from IPFIX data are combined. The system automatically derives firewall rules from this database. These make it possible to closely define permissible activities for individual applications. This brings the administrator a big step closer to the goal of micro-segmentation - with significantly reduced effort and a lower probability of misconfigurations.
Responding to network dynamics
Establishing filter rules for micro-segmentation just once is not enough. A targeted response to the frequent changes in the network is just as important. Manual adjustment of firewall rules at the level of individual
rules at the level of individual assets is time-consuming and should only be used in exceptional cases. Rather, the current research goal is for the system to identify changes in the network topology and the behavior of assets independently. How sensitively the system reacts to changes also depends on the security status of the assets involved. For updating, the system calculates the applicable 'delta' between the current status of the network and the time of the last rule generation. The result is new firewall rules to be changed and removed. As in the initial micro-segmentation step, these adjustments are not automatically enforced by the system, but represent suggestions that must be approved by the administrator.
Mastering increasing complexity with AI
In summary, it can be said that industrial digitalization is dramatically increasing the dynamics and complexity of IT/OT networks. Concepts such as IIoT or Industry 4.0 ensure that network architectures are becoming increasingly distributed and are characterized by a growing number of increasingly complex components. At the same time, the human brain is barely able to penetrate this complexity.
A shortage of specialists, time pressure and poor usability mean that only a few specialists understand these networks sufficiently. Network behavior is becoming a black box for IT admins and OT operators and, due to the high level of dynamism, there is no longer an 'up-to-date' network plan. This also has an impact on IT/OT security: dynamic systems are needed to respond to the new framework conditions. In a dynamic and complex environment, security policies and firewall rules must be defined and adapted in such a way that they do not hinder legitimate applications and meet a high security standard. Today's methods of network protection, such as automatic detection and manual countermeasures, will no longer be sufficient in the future to provide effective protection against increasing cyber risks.
The authors: Arnold Krille (left) is Head of Product Development at cognitix, Simon Daum is Head of Research at Genua.
© Genoa
Artificial intelligence can take on important supporting functions in order to manage the increasing complexity of communication networks in the long term. The aim must not be to create an automatic system for network security, but to provide intelligent support for the operator.
Genoa
OT Security is not fairy dust
A modern strategy for OT security combines rules, procedures and measures with the defense-in-depth principle and AI-supported attack detection - and takes the most important OT security protection goals into account from the outset.
