J. Schmalz
Plug-and-work as the maxim of gripping technology
Grippers for collaborative industrial robotics must support the flexibility of robots - in terms of adaptation, commissioning and operation. Dr. Kurt Schmalz, Managing Partner of vacuum technology manufacturer J. Schmalz, explains the background.
Dr. Kurt Schmalz, J. Schmalz: "The key word is flexibility: when developing grippers for cobots and lightweight robots, it is important to avoid anything that restricts the user."
© J. Schmalz
What technical developments are currently taking place in grippers for collaborative industrial robotics?
Dr. Kurt Schmalz: The key word is flexibility: when developing grippers for cobots and lightweight robots, it is important to avoid anything that restricts the user. This starts with adaptation and commissioning: It must be possible to teach the robot intuitively, without specialist knowledge. The adaptation and commissioning of the grippers must be just as simple: Plug-and-work instead of complex programming. Furthermore, the grippers must be flexible enough to support economical automation, even for batch size 1.
... in the sense of Industry 4.0.
Kurt Schmalz: Exactly. One option here is end effectors that can adapt to the workpiece using sensors, camera technology and valves. Alternatively, suitable grippers must be available at short notice and quick to adapt. The short-term availability of individual grippers can be increased with the help of engineering tools and additive manufacturing processes, as with our SLG lightweight gripper.
And what does the design as such have to look like in order to achieve the desired flexibility?
Kurt Schmalz: The design must correspond to the flexible application possibilities of the robots: Operation and control take place on the gripper itself - via buttons or via NFC and smartphone. Cobots and lightweight robots have a limited payload, which requires correspondingly light and compact grippers. The rule is: the lighter the gripper, the heavier the workpiece can be. And the lower the mass to be moved, the faster the movements can take place. This ultimately leads to shorter cycle times and lower energy consumption. Despite the tight weight specifications, we develop smart grippers that meet the demand for autonomous and self-learning systems. We also take all safety-related aspects into account in the design so that humans and robots can work together safely.
What role do you think inspection functions will play in grippers in the future?
Kurt Schmalz: They are already playing a role. We integrate many intelligent functions into our end effectors because cobots usually have few interfaces. For example, sensors in our devices collect data that is relevant for functions such as predictive maintenance and condition monitoring and pass it on to the higher-level controller. This makes separate sensors superfluous.
With vacuum grippers like the ones we offer, the issue of "integrated functions" also includes the question of how and where the vacuum is generated. If, for example, the robots are used in mobile warehouses, our electric vacuum generators, which do not require external compressed air, are ideal.
Schunk
The gripper becomes a testing device
In future, grippers for industrial robotics will no longer just pick up and position components, but will also subject them to a pass/fail test and document process stability. Prof. Markus Glück, Managing Director Research & Development at...
OPC UA
On the way to the world library
The vision has been in place since the end of 2014: OPC UA is to achieve the status of a globally recognized standard for the Industrial Internet of Things IIoT by 2019 at the latest. During the press conference at SPS, the Foundation took a stand...
Turck
More investment in software expertise
The economy is leaving its mark: compared to the previous year, Turck expects total sales of around 640 million euros for the 2019 financial year, a decline of 3%. Nevertheless, Managing Director Christian Wolf is optimistic.
SPS 2019
A look back at the fair
The 30th SPS was the highlight of the automation industry at the end of November. The keywords 'digitization' and 'digital transformation' were visible right through the halls. The main trends can be seen in the film below.
Video
SPS 2019 in retrospect
The 30th SPS, the trade fair highlight of the automation industry, took place at the end of November. The buzzwords 'digitalization' and 'digital transformation' were visible throughout the halls - the most important things in the film.
Sieb & Meyer
Dynamically driving high speed motors
Under the name SD4x, Sieb & Meyer is developing a new generation of frequency inverters for high-speed applications. The first of these is the SD4S version, which is designed for small high-speed spindles and motors with a power output of just a...
