Profibus & Profinet International
New profile for robot systems
In addition to the Profisafe, Profidrive, Profienergy and PA profiles, Profibus & Profinet International (PI) is expanding its technology portfolio with the profile for robot systems. The 'Profile for Robot Systems' working group is responsible for the development.
© Schunk
One of PI 's core tasks is the cross-manufacturer standardization of data interfaces so that communication in automation systems is simple and interoperable. In modern production lines, more and more stationary robots are being integrated as complete systems in order to increase the degree of automation and reduce costs. As the production line is typically controlled by a PLC and the user programs the production line application via the PLC programming system, there is a need to be able to control and program the complete robot systems from different manufacturers integrated into the production line in a standardized way via the PLC programming system.
Against this background, a uniform data interface between the PLC and the robot controllers is now to be defined in order to make robot programming uniform - and therefore more efficient - for PLC programmers and PLC providers. This data interface should enable robot programs to be written completely in the PLC. This means that the PLC manufacturer only needs a single robot library based on this data interface, while the robot manufacturer only needs to implement a single interpreter for its robot controller. The robot functions are to be called via the data interface and the required robot status information reported back to the PLC.
The primary target group of this interface concept are the PLC and robot programmers who implement a machine or production line including robots (OEM), but machine operators and system operators also benefit from this (end customers).
For implementation, all known robot functions are to be defined in this data interface in a manufacturer-neutral manner, with the focus being on the handling of applications. This will be based on the preliminary work of the 'Uniform Robot Data Interface' project group.
Ethernet-APL
The standard is
Standardization work has been underway since 2015 and the intrinsically safe physical layer designed for 2-wire cables called Ethernet-APL is now available; the first products are ready for the market.
IO-Link
Second Test Lab in China
At the end of May 2024, the China-based company Nanjing Loyst Industrial Networks was recognized as a new IO-Link test lab. This brings the number of IO-Link test labs worldwide to four.
Profibus
PI Magazine 1/2023
As part of our current April issue, we would like to share the latest supplement from the Profibus Nutzerorganisation e.V. with you. You can find the PI magazine as an e-paper here.
