Artiminds Robotics at the SPS 2024
Program robots easily
© Artiminds
At SPS, Artiminds will be showcasing a robot-based cable handling application (image) that detects, picks up and joins flexible cables in connector housings. A particular focus here is on process-related real-time data analysis.
In addition, Artiminds now supports line profile sensors from LMI Technologies with its Robot Programming Suite (RPS). The RPS enables precise detection of the cable position in order to efficiently automate complex robot applications with multidimensional image acquisition. Robot programs can be easily created and executed directly on the standard controller of the industrial robot without additional hardware. At SPS, the company will also be focusing on process data analysis using the Learning & Analytics for Robots (LAR) software. This makes it possible to automatically record and visually evaluate sensor data such as force measurements. This allows deviations in the process or causes of faulty insertion processes to be precisely identified.
Hall 7A, Stand 141
Physical AI
Humanoid Robotics at BMW in Spartanburg
 "Physical AI" combines digital AI with real machines and robots. This allows intelligent systems, such as humanoid robots, to be integrated into real-world production processes. Following the successful deployment of the Figure 02 humanoid robot at...
