Kunbus
Raspberry Pi-based for the energy sector
With the RevPi Flat, Kunbus presents an intelligent IOT gateway based on the Raspberry Pi 3+ Compute Module.
© Kunbus
The Linux-based, freely programmable, compact and flat top-hat rail module is suitable for industrial use and offers two separate Ethernet interfaces as well as an integrated 3-port switch and 8 Gbyte internal eMMC memory. The device also has two RS485 and two USB 2.0 interfaces, as well as an analog input and a digital and analog output. Furthermore, a TPM (Trusted Platform Module) with comprehensive security functions is integrated into the gateway, offering data protection, secure storage processes and protection against external software and hardware attacks.
The module supports communication via wireless M-Bus and is Bluetooth and WiFi-capable. A customized Raspbian OS with real-time patch is pre-installed as the operating system. Thanks to the open platform concept (including full root rights), the RevPi Flat offers maximum design freedom, according to Kunbus. Individual functions can be programmed without effort and allow the implementation of a wide variety of projects, such as the establishment of modern, decentralized energy management or the optimization of existing processes. This makes it possible to record energy-specific values, map process-relevant data and manage master data and maintenance logs. Photovoltaic, wind power and solar systems can be controlled and monitored, ensuring smooth operation.
Kunbus
IPC based on the Raspberry Pi
Revolution Pi is an open, modular industrial PC from Kunbus based on the Raspberry Pi. Housed in a slim top-hat rail housing, the three available basic modules can be expanded with a variety of suitable I/O modules and fieldbus gateways.
Kunbus at the SPS 2021
Alternative to PLCs
The RevPi Connect+ feat.Codesys from Kunbus can be used as a modular and powerful small controller for a variety of different automation tasks and, according to the provider, represents an alternative to complex and cost-intensive PLCs.
PTC
Spatial Computing - The Status Quo!
The term spatial computing dates back to 2003 and stands for the interaction between man and machine. The technologies virtual reality, augmented reality and mixed reality in particular stand for this term. Is spatial computing revolutionizing the...
Kunbus
UL certification received
Kunbus has received UL certification for its open source IIoT gateways RevPi Connect. This means that all base modules in the 'Revolution Pi' family are now approved in accordance with UL standards.
Rutronik
Which standards does Industry 4.0 use?
In the implementation of Industry 4.0, wireless technology is making inroads alongside gigabit cables. The question is therefore no longer 'whether', but rather 'with what' wireless integration will take place. Here are the most important answers.
