Remote monitoring
Quelle: CiK Solutions | Inka Krischke,
Cloud-based data access
The Hobo RX3000 from CiK Solutions is a remote monitoring system with a data logger function and other features that, according to the manufacturer, are otherwise only available in devices for research purposes.
© Cik Solutions
As a result, the station combines the flexibility and sensor quality of expensive systems with the convenience of plug-and-play operation and also offers a built-in LC display. The monitoring system has a wide range of expansion options. Its features include cloud-based data access, plug-and-play operation, compatibility with a range of external sensors, easy provision of data via the Internet and alarm messages via SMS/email.
The system also has a double weatherproof housing. Function-critical electronic components are sealed in a secondary housing, while weatherproof sensor connections keep moisture out.
Delta Logic
Update brings support for TIA V19
Delta Logic has updated the 'Accon OPC UA Server' software to version 1.4.0.0. The new features include support for TIA Portal projects of version V19 and for the latest firmware for CPUs of the Siemens S7-1200 and S7-1500 controllers.
CADFEM / Ansys
Test digital simulation live
On September 26 and 27, students at Amberg-Weiden University of Applied Sciences will be able to find out how computer simulation can be applied directly to research and development projects. CADFEM and Ansys invite you to the big live simulation...
