Router
Quelle: Westermo Data Communications | Inka Krischke,
Can also be used as an Internet gateway
Westermo's MRD-405 is a CAT-1-capable LTE gateway for industrial M2M communication. The broadband router is suitable for remote access to SCADA systems, HMI and PLC stations and can also be used as an Internet gateway.
© Westermo Data Communications
Thanks to its compact design and voltage range of 10 to 36 V(DC), the device is particularly suitable for industrial applications. It can be integrated into networks using the built-in two-port Ethernet switch (10 Mbit/s or 100 Mbit/s). It offers uplink speeds of up to 5 Mbit/s for data transmission and a maximum downlink speed of 10 Mbit/s. Up to 5 Mbit/s can be achieved via HSUPA and 7 Mbit/s with HSDPA. The top-hat rail housing with IP40 protection features a SIM card slot that works with SIM cards such as static IP-SIM, M2M-SIM or commercially available SIM cards. Thanks to 'Connection Management', the connection is continuously monitored and many network-related problems are solved automatically without user intervention. The 'WeOS' operating system with a 'Stateful Packet Inspection' firewall and an OpenVPN/SSL VPN client provides the necessary cyber security. Functions such as static and dynamic routing, RIP, VRRP, NAT, IPsec VPN and port forwarding are also on board.
Delta Logic
Update brings support for TIA V19
Delta Logic has updated the 'Accon OPC UA Server' software to version 1.4.0.0. The new features include support for TIA Portal projects of version V19 and for the latest firmware for CPUs of the Siemens S7-1200 and S7-1500 controllers.
CADFEM / Ansys
Test digital simulation live
On September 26 and 27, students at Amberg-Weiden University of Applied Sciences will be able to find out how computer simulation can be applied directly to research and development projects. CADFEM and Ansys invite you to the big live simulation...
