Panel PCs
Quelle: Welotec | Lukas Dehling,
Various protection classes available
With its Saiph panel PC series, the complete solution provider Welotec now offers a flexible solution for harsh environments.
© Welotec
All models are available with IP65 protection on the front as well as with all-round protection - either IP66 or IP67. The series is based on the same mainboards and uses the same components. Operating system images can therefore be used across the entire inventory, regardless of the variant. The devices include an industrial SSD with 128 GB in mSATA format, 4 GB of vibration-protected soldered RAM, IP67-protected M12 cables for LAN, power supply and 2 × USB as well as a pre-installed Windows 10 Professional IoT operating system for industrial use. The PCs are available in two housing variants and screen sizes of 10.4 inches, 12.1 inches and 15 inches in the classic 4:3 ratio.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
