PC technology
Lukas Dehling, Lars Bube | Lukas Dehling,
New competition for the iMac?
The startup Modinice is launching a newly designed office PC on the market. The all-in-one computer requires only one cable, is easy to retrofit and can carry up to two monitors. Series production has already started and two distributors are already on board.
The 'Modinice M1' is intended to combine design with the practical requirements of modern office PCs.
© Modinice
Fancy Apple computers are usually only found in creative work environments. In most offices, however, there are still classic office PCs whose design has changed little over the last twenty years. Mike Finckh, Managing Director of Conecpt International, therefore wanted to develop an office computer that combines design with the practical requirements of modern office PCs. Together with two industrial designers from Munich, he designed the 'Modinice M1'.
Finckh deliberately opted for a Windows system for use in companies: "More than 90 percent of all PCs in the office environment run on Windows, as most ERP, production, service and finance programs are based on it. We want to ensure broad usability." However, the Modinice PC is also available without an operating system so that Linux or an existing Windows license can be installed on it.
Marketing and distribution via crowdinvesting
Finckh has founded its own start-up to market the Modinice. The test phase with customers and multipliers has already been successfully completed and series production has started. According to Finckh, the PC will be sold via the distributor Also. In order to successfully position the Modinice on the market, Finckh has launched crowd funding on the crowd investing platform Companisto. The crowd's investment will be used for marketing and sales.
Aufgeschraubt
Die Chips im neuen Apple iPad Air 2
Kaum im Laden erhältlich, wurde das neue iPad Air 2 auch schon von den Kollegen von iFixit zerlegt. Wie bei jeder neuen iPad-Generation gibt es Gewinner und Verlierer in der Chip-Industrie. Die Bilderstrecke zeigt die bislang bekannten Chips mit...
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
