Panel PCs
Quelle: gbm | Inka Krischke,
Landscape or portrait format
The UTC-320E all-in-one computer from Advantech is available from gbm. The touch panel PC is equipped with a flat 21.5-inch widescreen display and can be operated either via a projected capacitive or a resistive touchscreen
© gbm
It can be used in both landscape and portrait format. Thanks to the Intel Haswell i5-4300U processor and the expandability of the RAM to a maximum of 8 GB, the computer offers sufficient resources for computing-intensive applications. Six USB and two serial ports are available. The Panel PC can be integrated into existing network structures via its two GigaBit Ethernet ports; there is a WLAN module for wireless integration into networks. The Panel PC can be flexibly expanded with various peripheral modules using existing cut-outs. For example, barcode, RFID or magnetic card readers and a 5M camera can be attached. Standard VESA drill holes enable mounting on walls or support arm systems using a corresponding bracket. Thanks to its removable frame and installation depth of just 43.5 mm, the Panel PC can also be installed in a control cabinet.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
